XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20721)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20721 Build 20721.1.4.0 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20721 Build 20721.1.4.0 PV
- Pagepool: 6M
- Rom date: September 2, 2008
- ROM Version: 20080902C4WWE
- High Speed ROM.
- Port from Samsung SGH-i908 Omnia ROM
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20721
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v3.0.0.0 by Julien Schapman
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Some changes from my previous rom (build 20275)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
The link is available now.
ATOM ROM 20721 - PDAVIET
PASSWORD for unpack: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
duongndd89
Rom hấp dẫn nhất phần camera driver , up host bác sơn ơi . Em đang chờ tin bác từng giây đây . Theo tin tình báo là bác up lên host trước 12 giờ cho đúng ngày bác nhỉ. Ăn mừng 2/9 cho anh em PV cái đi
phamcongli
Rất tiếc vì không thể xài rom mới của bác sơn được vì con Atom của em đã có chủ mới ...hixhix .
duongndd89
Tình hình rom đang đc up lên host . Các bác chuẩn bị đi nha , 123 nhào vô súp liền ah :)). Cứ như đc nhận thưởng vậy ;;)
@linh_ck01 : tui ko alo cho ông chắc ông ngũ luôn đi nha
linh_ck01
niềm háo hức, sự hồi hộp lẫn hy vọng về một bản ROM đẹp và hoàn chỉnh hơn những bản cũ luôn âm ỉ cháy trong anh em của room Atomvà nhất là trong một ngày mang nhiều ý nghĩa như hôm nay-ngày 2/9.
Cầu mong những điều tốt đẹp nhất sẽ đến với anh, xin cảm ơn anh ..
hien1982
đang load rom về và một ngày thức khuya lại đến để thưởng thức rom mới của anh Sơn. Thanks anh Sơn rất nhiều!!!
takaru
Giờ em mới xuống HN . Đang down về . phải làm nhanh mới được vì 9h nhà em bị mất điện. Cám ơn a , nhìn bản rom pro lắm
Caohieu88
:D Topic bác Sonblack HOT quá, mải mê bên UIQ 3.0 lần đầu tiên em ở trong Top 10 Post bài. Cám ơn bác nhiều về bản Rom mới này!!
shpy
Cảm ơn bác Sơn nhiều lắm. Đã up xong tối qua.
GPRS, Camera thì vẫn thế, có lẽ do cái core nó nằm gần nhau. Chịu vậy.
Sound! Âm thanh bé hơn , chỉ còn ~ 80%. (đã set tất cả 100% volume rồi) . Đang ngồi test thấy âm báo tin nhắn nhỏ hơn mới chú ý test phần này !
stevennguyen89
Camera vẫn vậy có nghĩa là nó vẫn chớp nháy như mấy phiên bản trước phải ko bạn?
TranMinhMan
Lạ nhỉ, hum wa mình và A Sơn ngồi test trên con Atom của A Sơn thì ko bị vấn đề camera này!?:-? Ko thấy lỗi thì ko biết sao mà chỉnh đây!?:-??:|:-/
shpy
Chớp nháy thì bản này mình chưa gặp. Mà nếu như các bản trước, chớp nháy thì reset 1-2 lần là lại bình thường thôi.
Ý mình "vẫn vậy" là do phía trên có bạn nói sẽ có thay đổi lớn về camera, mình cứ tưởng sẽ có driver khác cho nó (để có thể dùng CoolCamera quay phim tốc độ cao hơn , hình ảnh đẹp hơn nhưng không bị 2 cái sọc ngang - hiện giờ nếu dùng CoolCamera vẫn nhanh và đẹp như vậy nhưng bị 2 sọc ngang)
Bạn tét phần sound giúp mình với.
stevennguyen89
Ok để mình test sound cho, có gì mình cho biết :D
stevennguyen89
Để mình quay lại cái lỗi, up lên để cho mấy bạn coi thử xem sao
linh_ck01
Vài nhận xét sơ khởi về bản ROM này:
+Giao diện nhìn mềm mại hơn với hình ảnh làn khói thuốc của Sonblack daika.... nhìn chung là quen thuộc với sự thay đổi chút xíu về icon battery <-- hiển thị dung lượng trên battery :D
+Đây là version có Flash format nằm trong phần Sys <-- tiện wá .. thanks daika ;;)
+Về kết nối: thừa thắng xông lên.. dựa trên nền Core 20275 cũ.. version này vẫn duy trì dc chất lượng kết nối mượt mà và ko bị gián đoạn ...
+Cam+video: chất lượng tốt và ổn định.
+Media: FM, media player = good
*** trên đây chỉ là vài nhận định sơ khởi ..các anh em nào có trải nghiệm khác thì share nhé ..
Chúc mọi người 1 ngày tốt lành..:D
shpy
Giới thiệu giúp mình về cái này đi bạn. Mình không thấy nó chỗ nào nên chưa mò tới !
VOKE
Bản này vẫn good như bản cũ , chưa có sự thay đổi nhiều ở bên ngoài ( chắc chỉ thay đổi trong core !? ) chưa tìm ra lỗi nào đáng kể cả , cách hiển thị dung lượng pin bằng số rất thuận tiện cho việc theo dõi !
Cám ơn pác Sơn , cứ tưởng pác dập tắt niềm đam mê Atom mà Stop Working thì buồn lắm !
