XDA FLAME - ROM WM6.1
VUNHATVAN
Bạn dùng ngay PPC, cài phần mềm CardExport biến nó thành USB mà format thích kiểu gì mà chẳng được
blackdoor
Bản ROM nâng cấp của EFN
O2 Xda Flame - EF MK3 WM6.1 20757 XIP/SYS ROM
ROM này gồm 2 bản:
- Standard EF-WWE.MK3s
- Ultimate EF-WWE.MK3u
Thông tin chi tiết từ xdaflameusers.com:
- 100% SYS Section from official HTC Touch HD (Blackstone) Build 20757
- 80% XIP Section from official HTC Touch HD (Blackstone) Build 20757
- 99% OEM section from R2A_32_WWE_601
- Bluetooth stacks from 20757 (18 out of 21 BT drivers)
- Pagepool set to 4MB
- Hardcoded Nikhilraut SB fixes to the XIP Kernel
- FInixN Battery & Radio indicators
- Official O2 Apps (Camera, Self Diagnostics, AutoConfig, Remote Control (U Only))
- Official O2 Drivers (Jaatayu MMS, MIDI, Wifisychip)
- Latest Windows Live
- Performance Tweaks (Caches and Glyphcache)
- iMate Ultimate UL6150 FM Radio (Arima)
- Xtended ROM Unlocker & a few tweak cabs (U series only)
- All Black Theme from the first boot
- SDK Certs (3 certs)
- Pocket Tweak CPL
- NET CF3.5
- Security Checks disabled
- OBEX Disabled by default. If you want to receive file via BT, enable "Recieve All Incoming Beams" in Settings first (Beam CPL).
Bản Ultimate có thêm:
Tools:
- Schap Advanced Config 3.1
- Vicott ClearTemp / QuickClear
- Vicott KeySwop
- ModaCo NoData (GPRS Control Applet)
- PHM Regedit
- DotFred PIM Backup
- RealVGA 96 & 128DPI (Good for getting more display space if needed)
- SIP Change (Automate SIP selection)
- psShutXP (Reset Tool)
- Gsoft SynchroTime
- WinRAR
Flame Tweak Cabs:
- Disable Locks - To disable Mandatory Lock enforced by MS Exchange for ActiveSync push mail
- NV_GPE_Switch_OFF & NV_GPE_Switch_ON (Experimental! toggle switch for active Nvidia display)
- Restore Black Color (for restoration of all Black color scheme without using Today tsk file)
- SDHC (NO-Wifi) toggle cab - For fast installation of SDHC driver BUT will disable Wifi - Uninstall to use Wifi again
- WM Tool - Advanced Process & Task Manager
Đã sửa lỗi về Active Sync
Tải:
Download LINK for MK3 Standard Edition
Download LINK for MK3 Ultimate Edition
Bản nâng cấp, sửa lỗi(Chưa test):
Download LINK for MK3 X Ultimate Edition
Download LINK for MK3 Xs (Standard Edition)
blackdoor
cài như nào bạn ui????
Bạn tải về, giải nén được một folder trong đó có tệp DSUU.EXE. Chạy tệp này say khi đã sync Flame với PC.
Hoặc chép tệp diskimage.nb0 vào thẻ rồi up từ thẻ.
tuandait
thanks khi nãy nhìn mãi không ra file diskimage.nb0 :|. jo được rồi. thanks nhìu!
blackdoor
Tôi dùng thử 1 ngày, mọi thứ đều ổn, boot máy có vẻ nhanh hơn còn pin thì tương đương như bản Cotulla 002. Có lỗi về hiển thị tiếng Việt: tất cả các Contacts đặt tên bằng tiếng Việt đều thành ô vuông. Với tôi cái này khá khó chịu, không biết bản nâng cấp có bị không.
tuandait
Tôi cũng đã dùng được 2 ngày. Và như bạn nói, tôi cũng thấy nó khá khó chịu. không những lỗ về tiếng việt mà khi nhắn tin hoặc nhận cuộc gọi, chỉ sau 2 - 3 cuộc là nó đơ hoàn toàn. nói chung là up lại bản Cotulla 002 và tiếp tục đợi 003.
Talobin
Cho mình hỏi. Mình dùng rom WM5 nhưng muốn có được mức thang chỉnh độ sáng như rom WM6 thì phải làm sao. Vì ban đêm dùng ở mức yếu nhất của WM6 rất vừa mắt và lại tiết kiệm Pin. Còn của WM5 thì dù thấp nhất vẫn rất chói !
blackdoor
Tôi thấy WM5 không sáng bằng WM 6 đâu, phải tăng hết cỡ backlight mà màn hình vẫn tối om.
Talobin
Ý mình là mức tối nhất mà. Ở WM6 mức tối nhất rất dịu mình nhìn vào ban đêm rất dễ chịu cho mắt, còn WM5 thì ko thể cho nó tối như vậy được. Có soft nào chỉnh được độ sáng từ 50 -> 0 thì tuyệt !
blackdoor
WM5 và hầu hết WM6 đều có 10 level trong phần chỉnh backlight, ở level thấp nhất thì gần như là tắt đèn backlight rồi.
tuandait
anh đã thử test bản sửa lỗi của EF MK3 WM6.1 20757 XIP/SYS ROM chưa? tình hình sao rồi anh?
blackdoor
Tôi chưa test thử được vì mấy hôm nay bận nhiều quá, cuối tuần mới thử được nên chưa thể có ý kiến gì về ROM này.
tuandait
Anh blackdoor đã test thử bản EF-WWE.MK4v chưa? em thấy bọn chúng vẫn kêu ghê lắm!
tuandait
em mới cài lên chưa biết dùng có lỗi gì không nhưng nhìn màn hình rất là mịn và đẹp hơn bản trước của nó.
[/IMG]
[/IMG]
bvnhan
Mấy hôm trước có tải về dùng ver O2 Xda Flame EF-MK3x, đến giờ mình đánh giá sơ bộ là chạy tốt, không bị treo khi cài một số phần mềm(đã test soft pocket alarm) như ver của Cotulla 002, màn hình nhìn mịn hơn, nhưng pin thì hết rất nhanh, có thể do mấy cái plug-in trong today(cái đồng hồ giống HTC). Tốc độ thì kém hơn ver Cotulla 002 một tẹo, đặt biệt là soft có sẳn trong đó nhiều.
Mình dùng Vista không cài trực tiếp bằng máy tính được, mình cài nó bằng thẻ.
Nói chung giờ mình vẫn đang dùng nó.;;)
blackdoor
O2 Xda Flame ROM Upgrade - MK4v
Bản ROM nâng cấp của EFN từ xdaflameusers.com. Bản này đã fix một số lỗi của MK3
Link tải:
http://www.mediafire.com/file/gzo2n2tzlmb/O2_Xda_Flame_MK4_WWE_20757-20273_Vanilla.7z
Đã sử dụng bản này 1 ngày, có một số nhận xét chủ quan khi so sánh với ROM Cotulla 002 như sau:
- Không có hiện tượng ngủ (SB).
- Giao diện có cảm giác đẹp hơn.
- Tốc độ khá nhanh, boot và load các ứng dụng nhanh hơn.
- Thời gian dùng pin khá hơn một chút.
- Camera sử dụng có vẻ ổn, không bị treo khi thoát ra (ROM Cotulla 002 tồi nhất ở điểm này).
Các điểm chưa ổn (với tôi):
- Không hiển thị tốt tiếng Việt trên Contacts, Lịch Phù Đổng..., một số ký tự như ư, ơ ... thành ô vuông
- Không chạy được O2 Media Plus
Nếu fix được lỗi hiển thị tiếng Việt thì đây là bản ROM tốt, có thể hơn ROM Cotulla 002. Các MOD giúp vụ này với!
Tôi đã quay lại bản Cotulla 002 vì Contacts của tôi toàn tiếng Việt, sửa lại lâu hơn UP lại ROM.
