Ạch, mới đi 1 tý mà ++.
e jaf nhiều rồi, e chuẩn bị những soft bình thường e dùng để jaf ấy.
dạ.............thữ fen...
dạ.............thữ fen...![]()
kết quả là vậy nèk bác ơi
JAF version 1.98.62
Detected PKEY: 9000AAC9
Card life counter: 99.99%
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\
Checking path: \Products\RM-504\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_C03_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx
Languages in ppm: English,German,Hungarian,Ukrainian,Russian,Romanian,Bulgarian
Detected P-KEY: 9000AAC9
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using èGÈ012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting..........PUBKEYS already sent...
.......Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 633, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05...
Erasing cmt zone 02FA0000 - 09D5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx...
Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
chỉ giúp em...![]()
tháo pin khởi động lại
thay toàn bộ file .r96 va .r01 cùng với profile nha!các bác cho em hỏi làm sao loại mod belle nhỉ![]()
giúp em cái đi anh vũ ơi..................
[/CODE]kết quả là vậy nèk bác ơi
JAF version 1.98.62
PRESS POWER ON NOW!
Using èGÈ012.005
Elf2flash 09.11.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Failed! Aborting!
Done!
chỉ giúp em...![]()
thử bung rofs2 ra xoá bớt vài file sound xem thử.
ko đâu. mình cũng jaf bản black grey . chắc cook nhiều nên file rofs2 quá dung lượng die máy đó. bản có cook gì không. bản trên hôm qua minh jaf ko thấy lỗi mà
link thay hình khởi độg và tắt máy ở đâu thế bạn
