ASUS P535 with WM 6.5 - first time EVER
Pretty
Nhìn nghiền quá mà down không được. Down được rồi thì để ngắm thui chứ không dám up. Có bác Mod nào rảnh build 1 WM 6.5 cho anh em PDAVIET xài đi.
gxg
Just for laugh! Happy funny...:):(
So.. I understand that I make the pdaviet laught! that I entertain you with my roms!
Also.. some people post here in vietnamese.. whitch I consider offensating, giving fact that I don't know vientamese.
I don't care is the owner of the forum. I'm a guest, I posted the "hilarius" rom for P535 only in his forum, I used a commoun language ánd is polite to adress into a commoun language as ENGLISH...
qqonline33
Oh... I'm sorry if i make u misunderstand... Really thank for your roms which u posted in PDAV. I'm using your rom
U'RE NOT GUEST. U're a member in PDAV's family. Me,too...
we want a rom with vietnamese, so... SORRY....
Hope your help, more and more...
Best wish for u...
haiphusy
Everything is ok, exept that I can read Vietnamese character on some programe, pls help me.
chucuoihp
i don't know different ROM from VNese and foregin. Your knowledge supply for me good Rom - this is impossible 4 me :p and thank for your help.
Some people like another ROm from another PDA member. It creat interest :D. I think it s a good idea
The last. like qqonline33 idea, Hope your help, more and more... ;););)
LeSScro
i encoutered a problem with GPS... my fault :-?? but i found a specific feature...
i use a prog : SIrfTECh to optimize my GPS sensibility to 57600 baud and change To connect at European Sat...
With WM6.5 unable to load SBAS because a new driver was ínerted in thí built and SirfTech won't update my SirfStar III...
I have reflash with WM6.1 20764, and all works great !
Then i Reflash with latest WM6.5 with office (thx for Update GXG):p
and now... iGO8 works much better and sensibility are back...:D
ancola66
Các KTV nhà ta đâu hết rồi mà lâu không thấy ROM WM6.5 "cây nhà lá vườn" nhỉ?
Để ROM Tây "lấn chiếm" thế này xấu hổ quá !!! :O:O:O
BÁO CÁO BÁC với BÁC PHẠM QUANG là :
*Build trên PV bị lỗi phần SYS ( Khi build báo lỗi default hv và use hv)
*Nhưng nguyên nhân chính là : Bản thân em thấy build này còn nhiều lỗi lắm, chạy chậm, vào Start menu chạy cứ cà giựt, hao khá nhiều ram (up xong chưa cài gì thêm chạy chỉ còn có 20M ram. Em chưa build bản này vì em muốn mỗi bản ROM phải thực sự là một tác phẩm hoàn hảo về Kỹ thuật và về Mỹ thuật (Cũng có thể vẫn còn lỗi nhỏ nhưng phải là chấp nhận được) chứ không làm theo số lượng:D
Hy vọng sẽ làm ra những bản ROM TỐT cho ASUS để khỏi phụ lòng anh em yêu mến PV:D
youbeetea
First of all: Many thanks to gxg for his great work!
Here are some smaller issues I detcted:
1) Im using Destinator 7 Navigation. It did a good job with elder ROM versions. Using this ROM, the software can no longer read my contact list. This isn't a serious impact, but makes navigation less convenient.
2) It is impossible to change the Today Theme. There is no way back to - let`s say - the old WM6.1 theme. Alternative themes are instantly overridden by the new theme. I like this new theme, therefore this is no problem for me.
3) If you test some of the alternative themes and switch back to the original theme, the black background doesn't reappear. It is replaced with the photograph of a peacock. Looks nice!
hook
Vâng. Sorry a. Thế có a nào test thử coi nó chạy ok ko nhỉ. Hay lỡ up roài mà có vấn đề thì mình cài lại bản 6.1 được ko nhỉ?
Cám ơn.
alanlee
Cám ơn.
Kẻo lên rồi xuống không được như thuốc tăng lực của TQ thì hỏng =))
hook
Tớ cũng up được roài. Mò mãi mới ra. Tạm thời chưa thấy lỗi nào cả. Ngon chạy cũng khá ok
kimcuongtu1978
Nhiều lỗi lắm đó chứ. Bạn chưa mò ra đấy thôi. Ví dụ như bạn muốn kết nối internet = gprs thì không có phần set proxy, tốc độ chậm, hay bị treo máy...
fifd2005
I tested it today
Thanks to GXG for giving me a chance to try WM6.5
But It is not a stable ROM
It gives error mesages
And It is slow not vẻy reponsive
I prefer Manilla 2D interface instead WM6.5 interface
