CÁC THỦ THUẬT, ỨNG DỤNG DÀNH CHO MÁY ĐÃ HACK.
Kojiro
RomPatcher+ v2.0
Bản final lần 1 :)
This is the list of the main differences in comparison with RomPatcher by ZoRn:
- New: it is now possible to apply/remove patches with just 1 click.
- New: added vertical scrollbar.
- New: introduced support for a new tag: "+SuperPage" which allow to patch the RAM area where is stored the SuperPage.
- New: two new options available "Dump Rom" and "Dump SuperPage".
- Fixed: Kern-Exec0 error when closing RomPatcher after a patch was applied.
- Fixed: doesn't unexpectedly crash when using large and complex patches.
- Improved: the shadow ram memory is now fully released when a patch is removed.
- Improved: better compatibility (supports also the OmniaHD, 5630, E52 and probably future devices).
- Improved: the "Patch Info..." option shows all the information lines contained in the patch.
thien13311
Mình nhầm :( Có hỗ trợ nhé :) Cập nhật thì vẫn cập nhật cho theo kịp người ta, còn việc dùng được hay ko là 1 chuyện khác :D
Mình đã test rồi. Vẫn như bản test v8+ SM à. Cài vào vẫn được nhưng không apply được (dấu X đỏ), à cài xong có thông báo lỗi gì đó, bằng tiếng anh nên không nhớ nữa (mình cài hồi sáng, đã remove rồi vì phải remove cái RomP hack thì mới cài được cái này.)
Up liên tục vậy chờ bản up khác vậy!
hungphilong
HelloOX * ALL IN ONE for H@ck your phone , new helloOx 2.0.2! *
What is HelloOX2?
HelloOX2 is an One step Hacking tool for all Symbian S60 3rd & 5th phone.
Hacking mean that it can get full access to your phone's system folders and files, with this capability, HelloOX2 could install a root certificate to your phone, and with the root cer & key pair you could sign any apps to install, include the Manufacturer capabilities requested apps. Completely fix annoying certificate error!
How to use it?
Install to your phone, just run it after install. All steps run automatic, just wait and see.
What HelloOX2 does?
1. Map drive
2. Unpack Hacking files to the virtual drive
3. Activate file system
7. Unmap drive
4. Install root certificate
5. Install RomPatcher+ (by Il.Socio)
6. Optional Install Modo (a full system files access file manager by leftup)
8. Done!
Notes:
RomPatcher+ is just a bundle app included in HelloOX2, it is not supporting by us, apply installserver patch in it should let you install any unsigned apps. Unfortunately, it may not works correct on some future device or firmware, if it doesn't works, please use the leftup cer & key pair included in HelloOX2 package to sign your apps.
HelloOX2 v2.02 update
- include RomPatcher+ v2.0 (by Il.Socio), totally replace the "old" ROMPatcher
- RomPatcher+ working on all Hackable phones, so all phones would install it automatic
- root cert and RomPatcher+ installation back to E90
- compatibility fix for N81
trangdem
MenuEditor 1.1.2
Bản MenuEditor mới. Ngoài các chức năng cũ đã được giới thiệu ở trên thì thêm các icon cho folder mới, nhìn rất pro, như trên con TouchPro của PPC.
Các bạn có thể thay hết các icon mặc định của máy.
Các bạn nên gỡ bản cũ MenuEditor ra, back up file .xml tại lại nha.
Cần có python và megamodule để chạy.
bạn cho mình hỏi 'back up file .xml tại lại nha.' là gì vậy?mình không hiểu
duskvnn
Muốn vào i/sys được thì bạn hãy vào RomPacher: OpenAll/Patch/apply hiện V màu xanh là được!
Chúc vui.
trước tiên mình cũng xin cám ơn các bạn đã nhiệt tình trả lời cho mình. Còn vấn đề bạn nói mình cũng làm rồi, mục N96Open4All đã hiện xanh rồi. nhưng sào ko vào Sys đc nhỉ.
DinhTuan
Cách này em thử trên máy N73 ME của em ngon lành, chạy nhanh hơn hẳn. Cách làm như sau:
Tạm dịch:
Download File đính kèm. Copy file MGXDatabasePlugin.rsc vào "C:\Resource\"101ffcd2.txt vào "C:\private\10202be9\", Sau đó khởi động lại máy.
Từ bây jo, chương trình nghe nhạc sẽ chỉ tìm bài hát trong thư mục "E:\sounds\" và Gallery chỉ quét tìm các file ảnh và video trong thư mục "E:\images\""E:\videos\" Vì vậy nên máy của bạn sẽ chạy nhanh như thỏ :p
Tuy nhiên, khi bạn đổi nhạc chuông trong profile, bạn cũng chỉ thấy nhạc chuông trong thư mục "E:\sounds\simple\".
Tác giả đã thử thành công với N95 8gb, N95-1, N82 và 1 vài máy điện thoại khác.
minh dung N73 ME, lam dung nhu vay,nhung sao van nhu cu,ai biet giup minh voi
onggia189
giúp mình với máy n 73 của mình không nhận nhạc va không refesh được như bài viết của zenki :Cách xử lý
Vào E:\Private tìm và xóa những Files sau đi
Trích dẫn:
e:\private\101FFC31\mpxv1.mpd
e:\private\101FFC31\pcv5.mpd
e:\private\101ffca9\harvesterdb.dat
mà máy mình trong ổ E ko có những mục trên chỉ có E:\private\101f8637 vaE:\private\101f875a ai biết giúp mình với
MaiDinh
Trích dẫn:
Mình không xài N73 nhưng mình nghĩ có tể tên folder khác nhau tuỳ dòng máy chăng? Bạn thử dùng chức năng tìm kiếm file của X-Plore xem sao.
Caominh171
Trích dẫn:
Cách này vẫn chưa khả thi đâu bạn, mình đã từng xóa đủ các file liên wa mà vẫn như cũ, nên hiện giờ mình ko xài ctrình nghe nhạc mặc định của máy nữa, chuyển wa dùng TTPod lun òi
MaiDinh
Theo đánh giá của riêng mình thì không phần mềm nào nghe nhạc hay và sử dụng lại chuyên nghiệp như trình nghe nhạc mặc định của máy.
0986212555
Đồng ý với ý kiến này! Có thể do bạn đó khi 4mat máy mà ko để thẻ nhớ trong máy nên bị tình trạng vậy, mình cũng đã từng bị như vậy & chỉ có cách là copy dưc liệu qua PC rùi 4mat cả máy lẫn thẻ & nhớ là khi 4mat máy phải để thẻ nhớ trong máy luôn, làm như vậy là sẽ được!
MaiDinh
Nếu đã quyết tâm phải format máy thì tốt nhất là nên format triệt để, cả bộ nhớ trong và ngoài, chép dữ liệu trở lại và cài đặt từ đầu để tránh "rác rến" còn sót lại.
onggia189
trước hết cảm ơn các bạn về những ý kiến .mình cũng đã cũng 4 mat đủ kiểu cả máy vvaf cả thẻ cũng the chép hết giữ liệu qua pc mà cũng vậy .mình cũng tán đồng ý kiến là nghe nhạc bằng phần mềm nghe nhạc của máy vẫn hơn . minh cũng thử nhiều phần mềm ngoài ma ko bằng mặc dù giao diện đẹp mình da thu cach nay :MAIDINH :" Mình không xài N73 nhưng mình nghĩ có tể tên folder khác nhau tuỳ dòng máy chăng? Bạn thử dùng chức năng tìm kiếm file của X-Plore xem sao." ma ko đươc . ai có cao kiến làm ơn giúp mình nha ở chỗ mình co anh bạn cũng có máy n 73 mình mượn thẻ thì máy mình cũng ko nhận giờ máy anh bạn cung bị y hệt mình luôn thế mới khó hiểu ?:-?
huyetthan
kojiro ơi,mình đăng kí trong imobile để lấy file cer nhưng ko lấy về đc. Đành vào trong OPDA để đăng ký nhưng khi nhập IMEI thì báo là đã cung cấp cho người khác rồi. Bạn có cách nào giúp mình lấy file cer đó ko?
