<?xml version="1.0" encoding="UTF-8"?>
<mm:content xmlns:mm="http://nokia.com/mmenu"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://nokia.com/mmenu ../mmenuschema.xsd" genre="musicsuite">
<mm:localization namespace="musicsuite_loc" source="musichomescreen.rsc"/>
<mm:item count="1" template="logical_template_6" id="msuitecps">
<mm:menuitem name="musicsuite_loc:R_MUSICHOMESCREEN_OPTIONS_OPEN" event="key:select" position="1" />
<mm:menuitem name="musicsuite_loc:R_MUSICHOMESCREEN_OPTIONS_HELP" event="custom:musicsuitehelp" position="2" />
<mm:query namespace="musicquery" service="Service.ContentPublishing" interface="IDataSource">
<mm:command mode="sync" name="GetList">
<mm:key name="type" type="string" value="cp_data"/>
<mm:key name="filter">
<mm:key name="publisher" type="string" value="MWPublisher"/>
<mm:key name="content_type" type="string" value="text"/>
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_text1"/>
</mm:key>
</mm:command>
</mm:query>
<mm:notify_request service="Service.ContentPublishing" interface="IDataSource">
<mm:command name="RequestNotification">
</mm:key>
</mm:command>
</mm:notify_request>
<mm
utput alias="mul_title" type="string" value="musicquery:results/[$index]/data_map/musicmenu_musicinfo_text1data"/>
<mm:query namespace="musicquery2" service="Service.ContentPublishing" interface="IDataSource">
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_text2"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<mm
utput alias="mul_detail" type="string" value="musicquery2:results/[$index]/data_map/musicmenu_musicinfo_text2data"/>
<mm:query namespace="musicquery3" service="Service.ContentPublishing" interface="IDataSource">
<mm:key name="content_type" type="string" value="image"/>
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_image"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<mm
utput alias="mul_icon">
<mm:image bitmap="musicquery3:results/[$index]/data_map/musicmenu_musicinfo_imagedata" mask="musicquery3:results/[$index]/data_map/musicmenu_musicinfo_imagedata_mask"/>
</mm
utput>
<mm:event event="key:select">
<mm:action service="Service.ContentPublishing" interface="IContentPublishing">
<mm:command name="ExecuteAction">
<mm:key name="filter" type="map">
<mm:key name="action_trigger" type="string8" value="MMInfoTrigger"/>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm:item count="1" template="logical_template_6" id="msuitemymusic">
<mm
utput alias="mul_title">
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC"/>
</mm
utput>
<mm:key name="publisher" type="string" value="MpxCollectionPublisher"/>
<mm:key name="content_type" type="string" value="integer"/>
<mm:key name="content_id" type="string" value="musicmenu_collectioninfo_numb1"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<!-- only one song present -->
<mm
utput alias="mul_detail" condition="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data = 1">
<mm:text value ="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_1_SONG"/>
</mm
utput>
<!-- multiple songs present -->
<mm
utput alias="mul_detail" condition="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data > 1">
<!-- %N songs present -->
<mm:text value ="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_N_SONGS">
<mm
aram value="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data"/>
</mm:text>
</mm
utput>
<!-- default - no songs present -->
<mm
utput alias="mul_detail">
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_NO_SONGS"/>
</mm
utput>
<mm
<mm:image application_uid="0x102072C3"/>
</mm
utput>
<mm:action service="Service.ActionHandler" interface="IDataAction">
<mm:command name="Execute">
<mm:key name="plugin_id" type="uid" value="0x10207C16"/>
<mm:key name="data">
<mm:key name="type" type="string" value="MessageToMusicPlayer"/>
<mm:key name="message" type="string" value="GoToMusicLibrary"/>
<!--mm:key name="Path" type="string" value="MusicMenu"/-->
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm:item count="1" template="logical_template_6" id="msuitefmradio">
<mm
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_FM_RADIO"/>
</mm
utput>
<mm
<mm:text value="FM Radio trong tầm tay"/>
</mm
utput>
<mm
<mm:image application_uid="0x10207A89"/>
</mm
utput>
<mm:key>
<mm:key name="plugin_id" type="uid" value="0x10282E5F"/>
<!-- At least one sub element is required in the data key. -->
<mm:key name="type" type="string" value="launch_application"/>
<mm:key name="launch_method" type="string" value="cmd_line"/>
<mm:key name="application_uid" type="integer" value="0x10207A89"/>
</mm:key>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm
<mm:text value="Music Stopper"/>
</mm
utput>
<mm
<mm:text value="Hẹn giờ tắt nhạc"/>
</mm
utput>
<mm
<mm:image application_uid="0x20036d13"/>
</mm
utput>
<mm:key>
<mm:key name="application_uid" type="integer" value="0x20036d13"/>
</mm:key>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
</mm:content>
