Đây là hướng dẫn đăng ký, còn thằng nào muốn có file rtf để register thì PM cho tao
2008 series Windows software registration instructions
Please follow these steps to register your software:
1. Once you have placed an order you will receive confirmation by email with an .rkf file to download. The files are available as both links to download and as an attachment.
2. Please download the file to your PC (select Save from the pop up window, not Run, in future there is no need to Run these files at all), and make a note of where you downloaded it. Please make sure that you save the file as .rkf (not txt, pdf, doc or anything like this). Otherwise the keys won't be recognized by LingvoSoft software.
3. Install the product if you haven't already done so and launch it on your PC.
4. If the Registration window appears, please press the 'Register' button and locate the key (*.key or .rkf file) where you saved it on your PC.
5. You will then see an alert window confirming the successful registration of the product. Now the software is registered and all its databases are available for use. If the software tells you that the registration was unsuccessful, please re-download the keys from the attachment.
6. If the registration window didn't appear when you launched the software, please go to its Help->Register tab.
