XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19213)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19213 Build 19213.1.0.4 PV_SB
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks: Special thanks to
Man PhamQuang
Trial Mod PhamNhatThanh
VIP nhocbanme
VIP vanlydochanh
Thông tin - ROM Information:
Pagepool: 6M
This ROM is built based on XIP & SYS 19213 from Kaiser Original ROM WM6.1
Hình minh hoạ - Illustrative Images:
Xem tiếp bài dưới
Sonblack
Các chức năng - Main functions:
- CE OS 5.2.19213 Build 19213.1.0.4 PV_SB
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 19213
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0 by Vicott Wong
- Task Manager v3.0 by FdcSoft
- Contacts Manager extension v1.6 by FdcSoft (support copying many contacts from Phone to SIM)
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.42
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080222.3.1
- Total Commander CE v2.5 by Christian Ghisler
- Mode SMS (change message display on PPC)
- PCM Keyboard v0.14 (support Vietnamese keyboard)
- X-Button for PocketPC v1.51 (Build 30744)
- rlToday v0.1.22b by Andre Andrian
- SRS WOW HD v1.2.10.0
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Now, support SuperSIM
- and more ...
- Change icon inside program folder and other application icons.
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
You only download the exe file included ROM and perform steps which program require until it finishes. Your PPC will be automatically hardreset later.
Cuối tuần vui vẻ.
Have a good weekend.
Sonblack
Sonblack
Link download đã có sẵn.
The link will be available.
DOWNLOAD FROM 4SHARE
Pass để chạy file cài đặt là PDAVIET (viết hoa nhé!)
DOWNLOAD FROM PDAVIET
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
TranMinhMan
Chúc mừng a Sơn, cuối cùng cũng chịu ra ROM mới!!!=D>=D>=D>
Anh chỉ thích xài Core xịn thui!!!:)):)):))
waterlemon46
hì hì ghiền tét rom mới quá . mong anh sơn sớm hoàn thành một bản rom super pro
meoden07
đang nóng lòng đây anh Sơn ơi
Cứ từ từ nhé, phải chỉnh vài thứ (Sonbalck)
Hoangdat_vista
Bản này anh Sơn đầu tư khiếp ha!!! nhìn pro quá. Quảng cáo quy mô lớn chưa từng có :D .Chúc mừng anh Sơn
goodmorning
liệu mấy hôm nữa thì có Rom hả anh.
sáng nay được nghỉ học em onile thấy anh ra bản core mới em thích quá.
hy vọng anh Son sớm cho mọi người cùng thưởng thức.
chào anh.
Thanks !!!
duyquehan
quản cáo rùm ben thiệt mà mọi người cũng hưởng ứng nhệt liệt ghê,chắc phải online 24/24 để làm người đầu tiên down và test Rom sau bác SON quá.
meoden07
vậy phải thức khuya òi đang nóng lòng đợi
haha em dang down đây
O9xx19xx29
Down ở đây hơi chậm - bác nào up lên mediafire để cho các bác sau down nhanh hơn
Sao khi cắm cáp vào bắt đầu chạy thì nó báo lỗi này nhỉ ?
TranMinhMan
Bạn phải extract 6 file trên vào thư mục C:\Windows\temp (và nên dọn sạch thư mục này), thì file Device Software Update Ultility.exe mới load lên chạy và up được. (Mình thấy đường dẫn trên hình bạn chụp ko đúng đó, nên báo lỗi là phải rùi)
P/S: Mediafire mấy hôm nay bị lỗi bạn à (down tới 99% là bị rớt)! Hôm wa A.Sơn up cực lém đó, up 3 host: mediafire, rapidshare, 4share luôn, mà chỉ có 4share là lên được thui! Mất cả tiếng đồng hồ đó!!!:|
Chúc vui!:D
Sonblack
Bạn chạy file ROM mà không thay đổi những gì có trên màn hình nhé. Không thì không uprom được đâu.
Nguyên tắc là up từ C:\Windows\Temp
Nếu không có làm đến sáng cũng chịu thôi!
O9xx19xx29
He he - trong khi mò mẫm mình cũng đã copy tất cả vào thư mục C:\windows\temp và chạy được rùi ( vì suy theo logic nó ko tạo được thì mình nhét nó cả vào đây xem sao - ai ngờ chạy liền )
Up xong thì lên đây định edit lại bài đã thấy các bác trả lời rùi - tại vì mình thấy mấy bản của Kumara thì để đâu cũng up được nên cứ nghĩ bản này cũng thế - hóa ra cần copy vào temp .
Đã up ROM okie - giao diện trông rất khoa học và Pro - chứ ko có vẻ đơn giản kiểu Touch - cái này trông Tech rất nhiều .
Để mình test thử các chức năng khác xem sao rồi có gì feedback tiếp
@ Lỗi Media 99% ko phải là do mediafire đâu - các cậu cứ dùng bản IDM mới nhất trên Internetdownloadmanager ấy - sẽ ko bị lỗi này - còn các bản cũ đều bị cả chứ ko phải do Mediafire ( Tested và kinh nghiệm từ các diễn đàn - updatesofts )
TranMinhMan
Đúng là người có kinh nghiệm thì sẽ thoát wa được, như mình xài Flashget cũng wa được, nhưng phần lớn ae ít người biết nên sẽ complain khi down ko được. Nên KTV hạn chế up host này thui!
Chúc vui!:D
O9xx19xx29
Nhận xét sau khi dùng và test chừng 30 phút
1) Tích hợp sẵn font tiếng Việt để duyệt web – rất tiện đỡ phải mất công cài font ( mình hơi tí là HR nên mỗi lần đều phải cài lại font ). Các bác nhớ để giao diện Clear Type cho nó mượt nhé ( Setting / System / Screen / ClearType / Enable Clear Type
2) Tự động GPRS – he he he -> mình cài quen rồi ko sao nhưng mà vẫn ngại cài – lần này cắm sim Viettel vào 1 phát là tự cài đặt cấu hình ngay ( hệt như W950i của mình – cứ cắm sim vào là nó tự động down và cài đặt cấu hình GPRS ). Nói thiệt với các bác chứ dù có Wifi nhưng mà em chủ yếu là dùng GPRS chứ có mấy khi có điều kiện wifi đâu vì café ngồi thì tuần cũng chỉ vài lần ( em có 1 cái sim được Free GPRS từ cty mừ - cây nhà lá vườn, hị hị )\
3) Mấy nút tắt truy cập nho nhỏ ở góc dưới bên phải để vào Phone, Kết nối gprs, Bluetooth, Khóa máy .. rất tiện – nhỏ nhưng mà hữu ích vì các chức năng này hay dùng.
Icon báo % của Pin đã là % nên rất trực quan – ko phải “đoán” như trước nữa, có cả tốc độ chip ở bên cạnh
4) Tốc độ cũng được cải thiện đáng kể - nhưng có vẻ độ “hao pin” cũng xêm xêm như các bản 6.x khác vì đều ngốn nhiều pin hơn Win2005 ( mới chọt 1 tẹo khi test đây đã giảm mất 3-4% rồi – thêm nửa tiếng nữa đã giảm đến gần 20% )
5) Lỗi khi Nhận bluetooth – vì mình dùng bản 6.0 của Kumara rất okie – gửi và nhận đều tốt tuy nhiên bản 6.1 của Kumara và bản 6.1 này đều ko thể nhận file qua BlueTooth được ( search thấy nhưng mà khi click chọn để gửi thì báo fail ). Mình đã lấy 2 máy để thử gửi sang ATOM là W950i và N6600 đều báo lỗi fail.
6) Có 1 phần gọi là Windows Update – mình check thử nhưng mà nó báo chưa có gì để update – phải chăng cái này là để update các phần cho Win Mobile giống như là update các pack cho Win XP ( trên PC ) ?
7) Duyệt wap và kết nối gprs ngon lành tuy nhiên khi cài Slick thì lúc kết nối có thông báo lỗi màu đỏ như sau:
Error!
Auth failed Socket error. Host not found. Error number 11001
( Mình dùng bản slick 0.42 mới nhất )
Ko biết bạn nào bị lỗi này ko và cách khắc phục thế nào ?
Nếu dùng mạng qua cắm cáp Sync vào máy tính nối mạng thì slick chạy bình thường và rất nhanh
PS: đã sửa được lỗi này bằng cách chọn kết nối của phần Access Point trong Slick là: Viettel Internet Settings chứ ko phải Automatic
8) Có thêm 1 số tiện ích và phần mềm nhỏ trong phần Program
