XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20924)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20924 Build 20924.1.5.0 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme
herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20924 Build 20924.1.5.0 PV (Beta build)
- Pagepool: 6M
- Rom date: November 4, 2008
- ROM Version: 20081104C9WWE
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0.1819.2129 (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.33 by A_C
- S2P v0.55 by A_C
- HTC Sim Manager for Pocket PC v6.58
- HTC Opal Enlarge Start Menu
- .NET Compact Framework 2.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 20924
- PHM Registry Editor v0.70 for Pocket PC by Philippe Majerus
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
Caohieu88
Nhanh vậy anh Sơn, em ko bóc tem trước nhưng mong sẽ Download đầu tiên, đành chờ vậy!!
PS:Em cũng Thanks anh đầu tiên nhá!
....Đã có ảnh nhưng vẫn chưa thấy Link!
hien1982
bóc ko được tem rùi!!!nhưng ko sao!!!hihihi...!!!đợi rom anh Sơn thôi!!!Thanks anh Sơn nhiều ha!!!
tiensylao
Banned
công nhận bác này làm việc với công suất cao thật.! mới up rom hơm qua giờ lại chuẩn bị phải up lại quá.!
thanhbinh123
không biết khi nao anh sơn mới pót len cho anh em nữa hy vọng bản này sẽ fix được nhiều lỗi
xdaatom21
cám ơn anh sơn nhiều lắm chúc anh vui vẽ gặp nhiều mai mắn!=D>
anh sơn ơi ban rom này có hao pin như bản code 20758 không?
tranthetai79
Cảm ơn anh sơn
Vừa ghé vào có ngay bản new atom. mai em dow về cài xem thế nào. chúc anh có nhiều sản phẩm hay hơn .Thay mặt bà con WmoBile cảm ơn anh=D>
Sonblack
Dùng Atom thì chấp nhận cảnh hao pin.
Rom build từ dòng khác và WM6 trở lên hao pin là đương nhiên.
Sợ hao pin thì hem dùng cái mới được rùi. :D
xdaatom21
cám ơn anh chỉ bảo .em chất nhận hao pin.miễng sao rom đẹp và nhanh là ok.mấy bản rom trước của anh chay ngon lành lần này là beta chất còn ngon nữa hihi gáng chờ để tét đêm nay luôn khổi ngũ hihi.cảm ơn anh nhiều
Caohieu88
Phải chờ thêm 1 ngày rồi :((... mà cũng ko phải vội đâu anh , cứ có là mừng rồi!! =D>
NhatToai
Final Version chưa vậy Mod.Sơn,vì thấy sig là Touch Pro :D(có mem hỏi thiệt á....)
Bản này bảo đảm sẽ good lắm đây các bạn.Chúc mừng ROM mới nhé!
xdaatom21
uh miểng có là vui rối chừng nào cũng được buồn ngũ wa hehe.gáng tí nữa coi sao hehe
Sonblack
Build là beta (bản thử nghiệm, có nhiều lỗi, mình sửa hơi bị nhiều, chỉ để biết build này từ đâu thôi) thôi mà Toại, tất nhiên cái sau phải ngon hơn cái trước. Vẫn làm cho Atom chứ, Touch Pro thì sau ROM này :D Ý của tay nước ngoài đó nói là kể từ khi dùng Touch Pro, khi nào sẽ là bản Final cho Atom. Mình đã nói là Atom vẫn ưu tiên kia mà :D
@All: Ngày mai nhé các bạn, một số lỗi nhỏ cần khắc phục vì thế cần phải test thêm tý, còn lấy sức mai đi làm nữa. Vui vẻ đợi thêm ngày mai nha và đừng spam là ok :D
AnhPheCT
Bản Rom WM6.1 core 20758 quá tuyệt rồi!! Nay có Rom mới!!! Xin chúc mừng!!! Và xin cảm ơn Bác SonBlack cùng các thành viên PDAviet!!!
st3v3nhai
bác sơn cho em xin cái "Enlarge Start Menu" của ATOM để cài riêng với bản đang xài nhé, mất công em up lên lại phải cài lại hết soft trong khi bản vừa rồi em thấy khá ổn định :)
Đây là khu vực ROM, không cung cấp soft, vui lòng không đề nghị ở đây. Hơn nữa nó được port từ dòng khác chứ không phải là file cài đặt! (Sonblack)
lenhutminh
Anh Sơn ơi beta là sao hả anh, bản trước rất ổn định, mong rằng bản này cũng ổ định, camera là vấn đề nan giải nhưng vẫn mong rằng nó ổn định hơn bản trước.
Anh cứ từ từ mà làm, Rom tốt thì đợi vài tuần cũng ok. thank anh Sơm vì đã đem lại niền vui cho ae dùng Atom.
KiD2034
Có ai down chưa dạ nếu chưa em xin póc tem 1 cái :D ,hum wa nghe anh Sơn bảo sẽ có Rom mới
Sonblack
I always build the rom for Atom. Non-Stop for Atom. Don't worry. Today, I release the new Atom ROM (Core 20924). Please wait...
Vậy mà sáng nay đã có rồi ,anh Sơn thật là Viet Nam Idol , chân thành cảm ơn anh Sơn đang háo hức UP Rom nè ngứa tay ngứa chân lắm rồi.:))
Caohieu88
Hic hic..lại về thứ 2 mới đau chứ lại..anh Sơn toàn chọn giờ độc ko ah..hôm 12h đêm.. hôm chọn buổi sáng :((
