maiyeuemnn
Có bác nào có link mediafire bản HD2_NDT_MIUI_GINGER_DEVELOPMENT_V26.1_cLK_Honeycom, bác chủ thớt bảo thủ quá, nhiều anh em có nhu cầu up lên mediafire rồi mà vẫn chơi mấy cái host khó nhai này (xin lỗi nếu làm bác chủ phật lòng nhé :D)
langthang262
Các thay đổi của bản MIUI gốc 1.9.9:
Recommended updates this week:
1. Browsing speed
Upgraded browser JavaScript engine to increase performance execution by 30%
2. Anti eaves-dropping
This weeks update features improved anti-eaves dropping, enable to prohibit app monitoring, monitoring of call information and other actions by third-party sources.
3. No SD card support for theme replacement, wallpapers, ringtones and other resources
Read on to see full list of updates and fixes…
System:
New key shortcut (MI-Button) to allow for shortcuts to Home screen, Screenshot capture, Search and Call functions. (Supported on MI-ONE, Milestone and DesireZ)
Optimisation of account management interface and login / details
Phone:
New automatic translation switch for APN setup (CMWAP networking can be set only)
New novice user guide
Improved anti-eaves dropping, enable to prohibit app monitoring, monitoring of call information and other actions by third-party sources.
T9 Pinyin less optimal results when matching the number of contacts
Fix in some cases lockscreen wallpaper cannot use full display
Fix in some cases due to problems with sensors causing problems with ring tone fade when picking up and problems with flip to mute
Contacts:
Add new contacts and support for restoring contacts from cloud backup
Fixed inaccuracy of A to Z (e.g, when you press P, it says O)
Messaging:
Optimisation of attachment into message recording, according to Mms automatically stop recording length limit.
Modify message delivery to optimise the default ring tone
Sending Mms fix in some cases inaccurate results
Lockscreen, status bar and notifications:
Added notification bar entrance of access control (simple mode)
Fixed FC caused by pulling down notification bar while changing themes
Fix status bar prompts novice user guide recurring problem
Fixed the brightness turns into the lowest while pulling down the notification bar in Single Page Mode
Fixed The lockscreen and music playback control appears while music is not finished playing
Fix lockscreen time display problem
Launcher:
Optimisation of long-press to open task manager opening speed
Fix desktop widgets text display cutting off problems
Themes:
Optimisation of local theme list loading speed
Optimize the local style, and other major changes to the application to open when the animation style, from the bottom up, with the same style of system
Page optimisation changes to sort local theme styles more efficiently
Repair custom notification sound, alarm is displayed as the default
Click for details page blank area leads FC problem
Clicking the details page causes memory issues leading to FC
Fix the local cache validation problems in some cases leading to problems effecting efficiency of loading
Gallery:
Optimisation of thumbnail and large view quality
Transparent image thumbnail display abnormal issue fixed problem
Fixed abnormal ratio of wallpaper in landscape browsing mode
Camera:
Camera is switched on immediately after repair of boot problems leading to FC
Fix open photo playback, change brightness, contrast, saturation leading to FC
Browser:
Upgraded JavaScript engine to (V8), execution of JavaScript pages increased by 30%
Default navigation page optimisation for quick access to new bookmark items
Fix quick access to sites, returning to navigation page does not refresh in a timely manner
Fixed page dragging failure in Top sites
Music:
Optimisation of the use of local album art and support for resizing.
File Explorer:
Fix listing image too large leading to confusion in the list of thumbnails displayed
Radio / FM:
Optimisation of headphone pull opens flight mode, no longer automatically exits radio app but instead shows a pop-up dialogue box
Sound recorder:
Fix problem recording from radio causes FC problem
Backup:
Optimisation of failed backup or items which abnormally cause failure, allow to delete corresponding items to continue backup
Optimisation of cloud backup stability
Fix SD card space warning, resolve issue leading to corruption in backups
Fix issue with local backup alarm restore causing FC issue
Calendar:
Optimisation when there is no account, the first time opening the calendar will give a prompt
Fixed issue of delayed update of menu after login
Exchange calendar fixes
Settings:
Optimisation of the system volume, when set to 0 the volume will not output notification tones
Optimisation of slider display segments
Optimisation of Wi-Fi password prompt, pop-up will display asking to re-enter if password invalid
System update:
Checking for updates in quick succession fixed popup error dialogue problems
Fix issue when switching to different network type e.g from mobile to wifi causes full package update to not be downloaded
Download manager:
Fix failed download does not receive notification message display
dragulia1
Bản 26.2 chạy khá tốt chỉ có market hơi chậm và quá chiếm dụng bộ nhớ. Hi vọng bản mới sẽ tốt hơn. ^_^
titanlys
bản 26.1 RAm em chỉ còn 171 =.=" hjc lúc dùng những bản trước là gần 260mb mà giờ bị vậy lag kinh khủng :(( chả bjk làm sao nữa....em thấy có mấy phần không cần thiết mà gỡ bỏ chả được :(
ntquynh89
Mình bị dính 1 lỗi thế này , khi đang bật wifi thì khi có sms đến là máy tự động rs lại , vào lại thì k thấy tin nhắn vừa mới gửi đâu
tienden
Sao đồ họa miui bị nhiễu sọc sọc và loan màu vậy anh em? chỉ mình cách fix được ko?
tuaneti
Vào Superuser, chuyển Root status sang Allow
kdtt8
mình đang sử dụng bản 25.1, tự nhiên hôm qua bị chết cảm ứng, ko tài nào mở được màn hình lockscreen. Các bác biết nơi sửa ko, mình ở TPHCM
tungbaitho
bạn task29 rìo cài lại là ok. Máy mình đang chạy mà bị liệt cảm ứng như vậy. Khi mở màn hình 3 mầu còn bị mất HSPL nữa cơ.
tuaneti
sao mình vào Superuser k thấy cái Root status như bạn nói vậy ?
Vảo Superuser, nhìn bên trên ngoài cùng bên phải có biểu tượng Preference --> Automatic reponse --> Allow
sao mình tìm hoài ko thấy supperuser nhỉ? các bác chỉ em với
Bác dùng chương trình Google Search apps của máy để search app đó nhé, Nếu Google Search không có nữa thì Vào market Download
dthungpro
bản 27 khi nào có vậy bác langthang.bản 26 bi lỗi auto brinetss bác fix luôn nha.thank
titanlys
em dùng bản 26.1 thấy nó chậm kinh khủng ln không còn nhanh như những bản 19.2 hay 25 nữa :(
