Cập nhật mấy thông tin hữu ích cho mọi người.
Để nguyên Tiếng Anh nhé, lười dịch quá:
5. Press and hold "Home" button to access Recent Menu/Apps Killer/Tasks
6. In Lock Screen
- Press Time Display and Slide down to go Main Desktop
- Press Call Icon and Slide down to go Dial Pad
- Press SMS Icon and Slide down to go Message
- Press and hold 'Home' button to active Torch
7. Multilang Keyboard with Dictionary
- Download MultiLing Gingerbread Keyboard on the Maket
- Open it and follow it step by step to download your language plugin
- Choose it for Input default
8. Uninstall an app or game:
- Press & Keep Icon on the Desktop, move it to Recycle Bin to Uninstall
9. Long press on the icon in Toggles will launch the settings for that icon.
10. Press "Menu" key and "Volume Down" key at the same time to print a screen.
The printed image is saved in the directory of MIUI in the sd card.
11. Press Home key at the first screen, you may preview screen thumbnails and add or move screens.
12. Slide from left to right to quickly delete a message or a call log.
13. You may hold down an icon by one hand to enter Edit Mode, and then use the other hand to slide the screen to move the icon to the target screen.
14. Double tap the time zone to launch the Music Player when the screen is locked.
15. Click the contact image in Calls, SMS and Contacts, shortcut menus will pop up.
16. The battery will display the percentage of left battery capacity by Settings>System>Battery>Notification Indicator Style>Percentage.
16. How to set IP dialing?
MIUI ROM can add an IP prefix for the called number in a strange land. You may set it in Settings>Common>Calls.
You may also long press the contact item before dialing, and choose “Make IP calls” in the pop-up menu.
17. When you are not available to answer the phone, you may slide up the panel to reject the call and to send a message to the caller at the same time.
18. How to set custom ringtones?
Put media files into the Media/Audio/ringtones directory in the SD card, (If there is none of this directory, please create one manually) and then select in Sounds in Settings.
Note: there are three directories under Audio, corresponding to the following tones:
notifications--notification ringtones
ringtones--incoming call ringtones
alarms--alarming ringtones
Supported formats: MP3, WMA, WAV, Midi, etc.
20. How to quickly delete items?
You may slide from left to right on the item and click on the red "Delete" button when it appears.
21. How can I share my network to the PC or other terminals?
Firmware of Android 2.2 and above support the sharing of mobile phones to other Internet terminal in the following method:
Go to "Settings" -> "System" -> "Share mobile network", you may choose to share the Internet connection by USB tethering or setting up portable Wi-Fi hotspot.
