JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
USB Cable Driver version: 7.1.27.0
Changing mode...Done!
Detected P-KEY: 90009699
Init usb communication...
Reading...
Phone Type: RM-356
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for phone...Detected P-KEY: 90009699
Found
MCU SW version: V ICPR72_09w44.4
20-11-09
RM-356
(c) Nokia
HW version: 1101
PCI version:
RFIC version:
DSP version:
APE SW Core version: V 40.0.005
APE Variant version: V 40.0.005V 40.0.005 V 40.0.005
APE Test version: eno_version
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
Production serial number: CBJ687497
Product code: 0559676
Module code:
Basic production code: 0552692
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 356039033309434
IMEI spare to net: 3A 65 30 09 33 03 49 03
IMEI SV to net: 33 65 30 09 33 03 49 53 F2
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0559676
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\
Checking path: \Products\RM-356\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM356_40.0.005_023_xxx_U01.uda.fpsx
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Done!
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\356039033309434_CRT_backup_1730223.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...ICPR72_09w44.4 40.0.005
Reading battery value...3847 mV
Init usb flashing...
Reading flashid...
CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 7
Rebooting to flash mode...
Waiting for the phone to reboot...
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting.................
Bắt lỗi là nghề của chàng =)) Đùa vậy thôi chứ thanks toàn là của anh ko à=)) thì thỉnh thoảng anh viết nhầm tí chú bắt lỗi anh nhìu wa'.tuổi trẻ tài cao![]()
Lỗi đó mình cũng bị đó, format 4 phím lâu lâu bị lại nên bạn thử backup sau đó Flash lại xem. Mình flash lại là ko bị nữa.Em nâng cấp lên v40 bằng wifi thì gặp tình trạng xem ảnh bị lỗi,lúc vào quản lý tập tin thì xem 1 cái 1 bình thường nhưng khi vào phần bộ sưu tập / hình ảnh vs video / thì ko có ảnh. Các bác giúp em với:|
Bạn Flash = Deadphone nhé. Trước khi bấm CHK thì máy bật, sau đó CHK xong thì tắt máy đi và bấm FLASH rồi làm theo chỉ dẫn hiện ra để flash (bấm nguồn)Mấy bạn cho hỏi mình Flash fw theo cả 2 kiểu bình thường và dead phone mà không được là sao zậy. Có bài nào hướng dẫn chi tiết xíu hông, tìm mãi bài nào cũng không làm được
Nút INF chỉ là hiện thông tin thôi, đâu có tác dụng gì đâu bạn :| CHK ấyCHK hay INF vậy? Mình thấy bài hướng dẫn kêu INF mà
Giờ thì nó thế này![]()
Cái này là mình cài JAF cho W7 đó bạn. Nếu không thì làm sao chạy được JAF
Buồn quá, ai flash cũng xong, mình thử cách nào cũng chẳng được . Hix. Giúp mình với(
Vẫn không được
Vẫn không được
bạn check vào 3 ô dead phone, manu flash, và factory set, rồi chọn INI, chọn dòng máy fw đúng rồi ấn FLASH
Thì em cắm cáp USB vào rồi chọn PC Suite và chạy PKEY > RUN JAF theo hướng dẫn JAF WIN 7 và làm theo hướng dẫn nhưng không được đójaf bạn có sài pkey ko vậy,cái nầy lúc trước mình có bị hết 1 lần rùi,hay là bạn chạy bằng USB vậy
Em thử hết vẫn không được anhbạn check vào 3 ô dead phone, manu flash, và factory set, rồi chọn INI, chọn dòng máy fw đúng rồi ấn FLASH
Mở lên lại vẫn bình thường![]()
em tìm cái pc khác thử xem sao,hoặc là em úp bằng NSU đi nhé,còn nếu có box thì up bằng box cho chắc ăn;,làm 1 thồi thì mệt lắm à,mà hình như lỗi nầy là lổi JAF em cài mà,bây h em tháo JA ra và cài JAF lại xem có dc ko
cmd 17 block
